Any performance gain by using custom widgets?
Answered eggroll 7 years ago
Is there any performance advantage to creating and using custom widgets, i.e. does JIM having a blueprint available because of the custom widget makes its use in multiple places in a prototype any more efficient than recreating the implementation over and over?
I guess by "custom widgets" I mean masters.
Dear Eggroll,
Probably the time will be less when generating the HTML however we don't believe you will increase the performance while simulating the prototype.
Internally some instances will be created to each master because the simulation of each is individual. An event inside a master should not affect the rest of the masters.
