Help needed with drop-down select and submit button
Known Jaakrooden 6 years ago
Hi! I want to create a simple select menu, where every selections are linked to different page. And also there should be a submit button, witch is used after selection made (as in example). Any suggestion, how to do that?
8f25bbf6306e5f64e8eb464693789a47
Thanks for any help!
Check out this example, it will help you see how to make this. https://www.dropbox.com/s/xv4dszkqnkduddf/SelectListCondition.vp?dl=0
