Hidden object taking up real estate
Known Lukáš Úradníček 6 years ago
Hello, I am building a hide away text field + label, in a dynamic panel (vertical alignment). The problem is, when I start the simulation, the hidden object still takes up real estate:
06094089f2682db65d5dcd653cc37f47
Taken up real estate:
8a8cd1dd87c709ce5e88423a2550d57c
After double-clicking on the hyperlink, the label and text field hides correctly. How to fix that?
Hi Lukas,
Can you send me a simple example so I can see what might be happening?
Check it out here.
Just hit simulate, and you will see the same thing as on screenshots.
The file I sent is no longer accessible so I put it on Dropbox.
Dear Lucas,
I've been testing your example and it's a bug that our engineers will need to solve in future updates. Meanwhile, as a workaround, you should add the group without using a Master.
Sorry for any inconvenience.
Sonia, thank you for the update. I sent more bug reports and requests / comments. Half od them are still pending.
Also thank you for the tip.
