Right Click Menu / Dynamic action at any given location of cursor
I'm trying to create a right click menu where the menu will appear where my mouse cursor is. Is that possible? If not, is it possible to create a custom tooltip that will appear in every cell of a column if i hover over it? Thanks a bunch!
Replies (10)
Is not possible yet but it's one of the things at the very top of our product's backlog so we will probably add it really soon.
Thank you very much! i know my company will be happy to hear that! Probably a question you get all the time, but do you know about when and do you need "testers" for that feature? Thanks again!
Glad to hear it's a top priority.
The recently released Justinmind version 6.4 includes two new constants: "Cursor X" and "Cursor Y".
Using these constants and a calculated "Move to" action will allow you to create a menu that will appear on the mouse cursor position.
You can find more info about this update on our blog:
http://blog.justinmind.com/wireframe-...
A nice thing about the "Cursor X" and "Cursor Y" constants is that you don't have to worry about calculating the positions of deeply-nested or scrolling components. You can just pop up the desired element at the cursor or an offset from the cursor.
How can you set the offset to the cursor? And how can you set the mouse 'down' and 'up' events to the right mouse button?
I'm not sure what you mean by "How can you set the offset to the cursor?", but I think I can answer your second question:
When you add an event to a component (a button, say, or hotspot — whatever you want to be right-clickable), you have the following mouse options:
690b75e355c07551fc467b86f1a294db
There is no separate "On Mouse Down" or "On Mouse Up" for the right mouse button, just "On Right Click" (that is, Mouse Down-and-Up). It does not appear to be possible to create an event for "On Right Mouse Down" or "On Right Mouse Up" at this time.
Also, I noticed that the icon for "On Right Click" is the same as "On Click", which seems like a very, very small UI bug.
FYI: I filed a request to have "on Right Mouse Down" and "on Right Mouse Up" added to the available options.
Hello everyone,
What I did to test this feature:
1) Create a button
2) Create an action for the button (On right click > Move)
3) Set Top = Cursor Y and Left = Cursor X
As mentioned on the asnwers above, I could understand that there would be the "Move to..." action when choosing "on right click". However, when I change the positions of the target (let, top) to calculated, there is only the possibility to choose one constant (Cursor X or Cursor Y) for each (Left and Top), there is not the expression beginning with "Move to..." as shown in http://blog.justinmind.com/wireframe-...
When I set Top = Cursor Y and Left = Cursor X, it sends the target far below on the screen.
Is there anything that I'm missing?
3e93dcb566889979019e5399b9d7d67b
Where do I find the "Move to" action? I could only find the "Move" after choosing the "on right click". So I could not build the expression
Thanks in advance!
Hello everyone!
I was able to solve this issue.
The problem occurs when you group different widgets with the context menu (let's say, a single column table) in the Outline organization layers,
To make this feature work, you can not group the context menu in any group, you have to leave it as a stand alone layer in Outline.
Hope it helps!
