filter a certain image
Answered Carlos Rgsj 6 years ago
Good evening, I'd like to know how to filter a particular image.
example: I have a gallery created with the Data Grid, after I click on a certain photo, I would like to open the image that was clicked on a larger size.
Hi Carlos,
The easiest way to do this would be to place hotspots over the images themselves on the data grid. Let me know if the data grid you've created prevents this from working.
You can see an example here: https://www.dropbox.com/s/m88c9ntfw9e8n4c/OnClickDataList.vp?dl=0
Many thanks helped me a lot, but I was trying to do this dynamically using the data grid being a big picture. being that in this model your .. you use a dynamic panel and put in each panel the background photo.
thank you so much.
Hi Carlos,
No problem - here's an example that should do that: https://www.dropbox.com/s/ir6e9zftq8eacex/SlideshowGridClick.vp?dl=0
