I can not get my "On Tap" event to repeat more than once.
In Progress Kghumaan 6 years ago
I am using a dynamic Data List. I have added an event on the "Current_row" in order to change style and hide/show other elements once a row is clicked. The functionality works just fine, but only ONCE. Once I try to repeat this event (i.e. go back to the view and click another/same row), the event does not repeat. Is there something I am missing? Is there something I need to do in order to make the events repetitive? Or should I make sure that the row is "toggled-off" somehow? Any help will be greatly appreciated. I followed: https://www.justinmind.com/support/how-to-edit-rows-in-a-data-list-in-your-web-prototypes/ in order to create the events once a user clicks the data row. Thanks in advance
We're having a little trouble visualizing the interaction you're looking to create. Do you have an example file you can attach (in .rar/zip format, or upload to a file sharing service like Dropbox) so we can get a better idea of how to assist?
Is there any way for me to send it to you directly? Project contains some sensitive material
If you have a subscription, you can login to the customer support portal and we can assist you there. If not, perhaps you could export the single screen with the data list and change any sensitive details?
