Datalist single row selection does not work in v 8.4.0 - change color to all clickd row
Not a Problem Arianna Poggi 6 years ago
This behavior is present even using the provided example at https://www.justinmind.com/support/change-the-color-of-a-clicked-data-list-row-in-your-web-prototypes/
The example is made with a previous version and notify that on opening the prototype.
I need to reproduce in v 8.4.0 the single selection exactly as the online example shows.
Thanks in adavance
Hi Arianna,
The example is working correctly. When creating your own example, make sure that you apply the event to 'Current_row_1' otherwise it won't work.
