Always on-top and position locked items in simulation
Answered David Ho 6 years ago
Hi, just started using it, great tool but need help on some functions.
I add a long retangle and put it at the bottom layer, simulate a long page need scrolling.
Then I add another small rectangle bar at the screen bottom. Set it as always on top and locked positon, to simulate an ads bar which is always on-top and stay at the bottom.
However, when I simulate it in the tool, the small rectangle bar move along with the page when i scroll it with the cursor.
Anything wrong?
Hi David,
It's hard to say why it wouldn't work without seeing the file itself. If possible, could you attach the file here? You can compress it to a .zip format, or upload it to a file sharing service like Dropbox and link to it here.
Hi Danielle,
Thanks very much for the response! I attached a zipped project file, please kindly help.
Rgds,David
Files: TEST.zip
Hi David,
The issue is that you need to use "Pin position" in the properties palette, rather than 'lock position'. I have edited your prototype to show this. Let me know if you have any questions.
THANKS VERY MUCH!
You are so kind and really helpful!
Rgds,
David
