Show icon when data list is changed
Answered Brett Edmonds 6 years ago
I have an on-click event that changes text in a row cell and records it the dat data master.
When that happens I am wanting to show an icon in that same row.
When i try it, it 'shows' the icon on every row NOT just the one that has its information updated.
Please help
Hi Brett,
Do you have an example file you could attach so we can get a better idea of what you're looking to do? You can compress it into a .zip format, or upload it to a file sharing service like Dropbox and link to it here.
Thanks, here you go.
What I'm looking to achieve is that when a user makes a selection using the checkboxes and clicks 'Add to Ask list', a star icon should turn on in the last column of the 'selected' rows.
Thanks,
Brett
The easiest way would be to use a new boolean data master field to store the visibility of such icon. Then, you should do a modify data master event to store the new value in the “add to ask list” button, previous to the current filter.
I'm not sure I understand what you mean. Can you give me more detail please?
Apologies for the late reply - we had a create an example and we realized a better way to accomplish this. Instead of using a data master field, you should create a variable that will store if the checkbox has been checked. Check out the attached prototype and copy those events.
