Mac Sketch files, imported into JIM on Windows 10?
Answered Info 6 years ago
I have a need to import Mac Sketch files into the Windows 10 version of JIM. A lot like Adobe XD does now?
You should run the Sketch file through the Justinmind Sketch plugin on the Mac, and then you can send the .vp file to the Windows 10 computer. You can learn about the Sketch plugin here: https://www.justinmind.com/support/justinmind-prototyping-tool-sketch-integration/
Bit long winded, especially as I'm a PC user and don't have a Mac. When will the plugin work on a Mac Sketch file. I know Adobe XD does and I believe invision also has this ability?
The plugin is within the Sketch application itself, so unfortunately you'll need to have someone with the Sketch application open and export the file using the plugin.
