Bringing in photo but with white background to it
In Progress Daniel Paul Tintle 6 years ago
I am trying to bring in a logo from photoshop into my just in mind project. Every time I do, it has a white background (square) behind it. The only way I have been able to change this is to customize the background of the image to fit the same background color on my prototype. However I have many screens right now and going back to the image to change the background to fit on each screen is counterproductive. Is there anything I can do?
You will need to make the image transparent in photo editing software. Right-click on the image in Justinmind, and you'll see an option to open and edit the image. Make the image transparent and then save it. Your changes to the image will be shown in Justinmind.
I opened it from the user interface in just in mind by right clicking and going to "image," and then "open with default app." My default app is photoshop and I had deleted the background of the jpeg image in there to make the background transparent. I then saved the jpeg file and the image still shows the white background in Just in Mind, even when I tried simulating. Any hints?
You might have to replace the image in Justinmind. If it's not showing as transparent in Justinmind after that, please attach the image here and we can test it.
Hi Danielle,
I've been trying to attempt it with a simple image and still not work. Please see attached,
fcecce0e2fbd913b984d02a898157ed0
That image is not transparent. You need to use photo editing software to remove the whitespace around the image. It should look like this:
bda3d989bcd65b638386ca148c24bc78
Oh wow I see now. I have been using photoshop to do so though. If I can't do it on photoshop, do you have some suggestions I can use?
You can create transparent images in photoshop. Learn how to do so here: https://www.templatemonster.com/help/photoshop-how-to-make-image-transparent.html
