Select list (drop-down) with nested option
Answered Jtolios 6 years ago
I would like to group related options in a drop-down list, similarly to the attached figure. The user should be able to select an option by checking the corresponding box. Is that possible in Justinmind?
Ioannis
Sure - just drag a Checkbox list widget to the screen. You can find it in the Widgets palette.
But, is it possible to incorporate the checkbox list as an option in a select list (drop down)? Is there such a component or do I have to combine different components?
Unfortunately no, there is no drop-down checkbox widget. You will need to combine different components.
