New Action with plugin
I want to develop a new action when I add a new event to widget.
Is it possible to do this operation through a plugin developed with sdk?
Thanks in advance,
Vanni
Hi Vanni,
There is no way to detect when an event has been created and create a specific action. You can create actions that the user will launch manually and use our APi to read data from the prototype.
Hi Sonia,
thank for your response.
I have others question :
1. is it possible to launch javascript code from a widget inside justinmind?
2. I'm seeing the sdk but I don't understand what type of plugin I can develop : I only see the "export" plugin, so I imagine that I can't create plugin for create new function, new event and so on, is it correct?
Thanks,
Vanni
Hi Vanni,
1. You can use the html widget.
2. It's not possible. Our Api reads to obtain data from the prototype you are using.
I reccomend you to check out this tutorials for further information.
http://www.justinmind.com/support/sec...
http://www.justinmind.com/developers#...
