how can i insert the variable into a text?
Answered Vadim_dorofeev ● 7 years ago
I need to insert the variable from the first screen into a text string in the second screen
Example: I have bought the *VARIABLE 1* , *VARIABLE 2* at the *VARIABLE 3* market.
Thanks!
You can use "Set Value" actions to set the value to the variable from an input field. Then, on the other screen, create an "On Page Load" trigger, with a "Set Value" action, which will set the value to a text element with the value of the variable. Check out the attached prototype. You can also check out our tutorials on variables.
