Input text field mask/format
Answered Tiago 6 years ago
I'd like to know if is possible to change the format/mask from an input data field.For instance, if I type 000011 the field automatically show me 000.00-11.
Sure - using the Substring and Concat functions. Check out the attached prototype to see an example.
Perfect! Thank you for your help!Also, is possible do the same but while the user is typing?
Yes, but you'll need to change the events a little. In the attached prototype, instead of using Substring, we use a condition to detect when the number of characters is a certain amount, and then Concatenate . and -.
Got it... instead of verifying the number of char, I need to setup it to verify each key pressed, for example...
What do you mean by verify? If the key has a specific value, for example?
By verifying I meant to check the data from the field. Instead, check the data only in the end, it could check the data each time I press any key while typing the number.
