Justinmind cannot be launched with Guest account in macOS 10.14.2
In Progress Raptor K 6 years ago
Justinmind v8.6.1 cannot be launched with Guest account in macOS 10.14.2 (same for 10.13.x)
I installed Justimmind with Admin account by dragging the application to Applications folder. When I switch to Guest account, I can see the Application icon in Dashboard & Applications folder, but when I try to launch it, it said the App has to be launched in Applications folder (which is already there).
Temp solution: in guest account, copy the Justinmind to desktop by Option-drag. Miracally the Justinmind can be launched without problem.
Please help!
This is likely a problem with permissions. To fix this, execute the following instruction in the terminal and try opening Justinmind again:
chmod -R 777 /Applications/Justinmind.app
Executing the command in admin user account solved the problem (need to use `sudo`). However, will it raise security/other problems?
