Hyperlink not working in requirements field.
In Progress David Feehan 6 years ago
I'm trying to add a url to a field in the requirements--in this case, "source", but the hyper link is not functioning. How do I add a hyperlink to the a requirement?
What Requirements software are you using in addition to Justinmind? Jira, TFS, etc?
I am using JIRA and the plug-in connector is working fine. I would like to create a custom requirements field in Justinmind and add a link to additional documentation that is in on our Confluence wiki. I can create a custom field in JIRA and add the link to that field but the only fields that I can import from JIRA to Justinmind are the "Name" and "Description". I would like to add a link in the Justinmind requirements called "Design documents" or "whatever name" and a link that can be hyperlinked to the document in Confluence. Is there anyway to add a functioning link to a requirement that will work?
Unfortunately that's not possible right now, because the requirements do not currently process HTML - only plain text. However, this capability is in our backlog, and I'll let you know when it's been implemented.
You are now able to add that link in the Description field now. Let me know if this works!
