Cannot export a functioning Prototype
In Progress Memzy98 5 years ago
I have finalised my prototype and it is fully functional on my dave of it although when it comes to exporting the prototype I receive the error "Some events could not be saved correctly due to some unsupported data. Check you are using XML-supported characters".
I have checked through the project and there does not seem to be any unsupported characters and on use, no function that makes alterations to a Data Master works.
Sorry about that!
If possible, can you attach the .vp file here so we can see what's causing the problem? You can compress it to .zip/.rar format to attach it here.
Attached is the exported version.
We haven't been able to reproduce the error you're reporting so far. Can you list out the steps you take for the error to appear?
