Is there a way to animate an x-y plot?
Answered Fadsir78 5 years ago
For example I want to show moving data point on a y function of x curve, when x value changes.
Do you have an example image/.gif you could attach?
An example is the attached graph of a linear relation. Say this can be generated form a data master of x and y values. Then I want to loop through the data master for each x and y pair, I. E each point, to make the point flash on on the graph.
Since I question is not answered, I presume there currently there is no in-built feature or plug-in that can do what I'm after. While researching I've learned that the R programming language is primarily designed for statistics / charting, similar to what I'm looking for. See snapshot below. I hope there is a way to integrate this with Justinmind or to consider this in the next upgrade.
giphy
