Integration with TFS
In Progress Fahminrahman 5 years ago
I am trying to establish TFS integration following the steps in this tutorial https://www.justinmind.com/support/justinminds-integration-with-microsoft-team-foundation-server/. But it is not working. Please help.
Thanks,
Fahmin
What happens when you try to import or export the work items? Do you see an error message?
Thanks for your reply.
Yes, the error is
"TFS connection problem
Can't connect to your TFS instance. Please verify the connection is configured correctly."
But I have provided my username, password, url and project key correctly. Please help.
Hi
I have the same problem
Lisa
Hi Lisa - what version of TFS are you using?
Hi Danielle, I utilize the version 16.131.27701
Thank you for the information. Can you also attach your log files? They should show the reason why the connection isn't working. You can find the log files by following this file path:
Hi!
follows the log files.
Files: logs.log
We don't see anything related to TFS in the log files. Can you try connecting to TFS in Justinmind and then attach your logs again?
