Import error for file exported from Adobe XD
In Progress Sumeet Kalindi 5 years ago
I exported a file having multiple screens from Adobe XD using the Justinmind to XD plugin. But when I try to import that file into XD it shows an error. Screenshots attached. Tried with just one screen as well. Unable to attach the exported Justinmind prototype file here.
Thanks for letting us know about this! Can you attach the Adobe XD and Justinmind files here? You'll need to compress them to .zip/.rar format to attach them here.
Here is the XD file and the exported Justinmind file I tried out.
We identified the problem - there's an element called 'Hotspot' in your Adobe XD file that's causing the crash. Do you know if there's anything different with the 'Hotspot' element and other Rectangles in your XD file?
The hotspot is a shape I use for adding a padding frame around smaller clickable elements. I think the plugin is unable to convert shapes which don't have a fill or outline. This might be the reason for the error.
We've updated the plugin, which fixes this problem. It should update automatically once you launch Adobe XD. Let me know if the problem is still occurring after updating.
I have the 1.0.2 version of the plugin. I figured that if I have any symbols, components, groups or compound svg shapes then the converted Justinmind file throws an error. I was able to get a readable file after I removed the headers, all svg images and also ungrouped all elements retaining just basic shapes. Its a workaround for now but I hope that gets fixed in the future versions of the plugin.
So the file is still crashing? If so, can you try uninstalling the Justinmind plugin in Adobe XD and try reinstalling it?
I tried re-installing the plugin. I am still getting the file error in the exported file.
Can you try reinstalling once more from this link? We made a small change. Thank you for your patience so far.
The attached file not working with Justinmind Version 9.1.3
It is not working from XD to Justinmind !!
/118b97434eea72a2847476553295bf8b
