How to set active items in a menu?
Answered Remi 5 years ago
As a designer I want my prototype to show the current page menu item in "active mode". Like, for example in the attached file.
Do you have any suggestions? Thank you
The easiest way would be to create different Dynamic Panels for each tab you want, and then create "On Click" + "Set Active Panel" events for each tab option, which will switch to the corresponding tab.
