Pan map with tooltip
In Progress Elisabeth Umbach 5 years ago
Hi all,
I have a urgent question: I have created a map with pan and zoom functionality according the instructions. Now I want to add a tooltip functionality (tooltip is shown when mouse hovers over certain cities). When I just group a hotspot over the cities this does not react any more once the map is moved. If I group the map, with the hotspot and the tooltip in a dynamic panel this does not work as well.
Any tips how I can achieve this?
Best, Lisa
The best way would be what you described - grouping the map, hotspots, and tooltip into a Dynamic Panel and then altering the events to move the Dynamic Panel instead of just the image, and changing the 'Insert Into' event to insert the new Dynamic Panel. It seems to work ok for us - not any different than the original version. How does it work for you?
