Loading Circle animation
In Progress Technical 5 years ago
Is there a tutorial or an example somewhere for a loading circle process?
Check out the attached example. It builds on the Countdown tutorial, but just changes the events to count up instead.
Hi Danielle,
I have already seen this tutorial, but I am looking for an animated circle that fills up around the perimeter of it
Do you have an example of that? I'm not quite sure what you're referring to.
Please see attached
Unfortunately there's no way to create that kind of element in Justinmind itself. However, you could use a gif of a loading circle in the prototype instead.
