Default Font Color for Scenarios is Black on Gray - hard to read
Under Consideration Cameron Gull 5 years ago
I'm using Scenarios more and more, but an annoyance is that each time I drag an Action, Screen, Decision, etc. to the window the label text color is black making it difficult to read. I have to manually change the color for each one.
I just noticed the following video sets the text label color to White... That's exactly what I want, but not what I'm getting.... Is this a bug or some feature I'm unaware of?
https://www.youtube.com/watch?v=NKAGPHpx2nc
They probably set the colors to all be the same by selecting them all at once (shift click), and then changing the text color to white. I'll let our team know that the ability to set a default text color in Scenarios would be helpful.
I would recommend setting the default text color based on "UI Mode". If the UI Mode is "Dark", the Scenario default text color should be white; if the UI Mode is "Light", the Scenario default text color should be dark. That would solve it for ALL users with, presumably, very little work on your side.
Thanks for the suggestion. In future versions, we're planning on changing the Scenarios canvas to white, so the text will be black and hopefully more readable by default.
COMPLETELY AGREE! Looking forward to the next update!
