Nav selection lost switching from screens or templates
In Progress Cbuz 4 years ago
Ciao, when switching to a different screen having an item selected in nav bar, when come back the selection is lost. Big loss of time
Is there any option to avoid this?
Thank you in advance for help
Claudio
You can create a Variable that stores the value of the item that is selected, and then on each screen, create an "On Page Load" + "Set Value" event that changes the value of the selected item to the Variable's value.
I did not explain the problem correctly: the issue is using the framework, during designing time, non in the result!
