Unable to save any prototypes
In Progress Frankc 4 years ago
I am running ver.8.7.8 . doesn't matter if it is an existing shared prototype or a new prototype I built to test this problem with. When I chose to save or save_as I gen an "Error saving file" alarm box.
See attached files.
Thanks for reporting this - it's a very strange issue. Would you be able to attach your log files after you try to save? You can find them by following this file path:
Thank you for responding. This morning I tried deleting the app and re-installing it. Same outcome. I am attaching the logs for you.
Files: logs.log
It will not take the second file. I don't understand why because I can open logs.log.1 in Atom txt editor.
OK, I copied logs.log.1 to my docs folder and renamed it. Here ya go.
From the log files, we see that the prototype is stored within Dropbox and that there is a permissions issue. Our dev team is going to look into this to see if it's an issue on our end that's causing this, but a quick test would be to see if moving the prototype out of Dropbox and to your local machine allows you to save it.
Just following up here - were you able to save the prototype on your computer?
