CONNECT TO AN API
In Progress Heliyabisadi 4 years ago
HI
how can i connect to an external api like this
get api.test.com/test/23
and use json data in justinmind
and also how can i set an event to run an js code?
Unfortunately you won't be able to do this in Justinmind. You'll be able to embed HTML into your prototypes using the HTML widget, but you won't be able to include code in events.
