Mobile App - Multiple Tokens problem
Having to re-enter a token into the mobile app each time is irritating and tiresome, specifically when 2 tokens are used. As well as having the App redownload the prototype each time.
Is it possible for you to implement a small list for Past used/previous used tokens.
As well as cache the last or last 2 downloaded prototypes so it redownloads only once changes are made to said prototype. Making it work similarly if you are logged in.
Hi Antonius,
Sorry for our late response. If you are Justinmind user you could avoid this by
doing log in directly into your mobile app and then you would be able to visualize your prototypes list directly without using any token.
Sonia
