can u give ui kit for Neumorphism? as there is only 1 option for shadow.
Under Consideration Rucha 4 years ago
can u give separate readymade ui kit for Neumorphism?
or else plz give more options in shadow, as there is only 1 option for shadow.
because we have to write separate code in HTML for this in css. it will be easy to do Neumorphism if given more options in properties field.
Thank you for the suggestion! I'll forward it along to our team. In the meantime, you can try downloading one of the UI kits we link to in our blog post about Neumorphism. Many of them come in Sketch or PSD files and you can use Justinmind's integrations with those platforms to export those prototypes to Justinmind files.
ok thank u :)
