Azure DevOps Integration
In Progress Suzanne Ryan 4 years ago
Anybody else having issues configuring the integration to azure devops? followed all the instructions in:
https://www.justinmind.com/support/justinminds-integration-with-microsoft-team-foundation-server/
and cannot get it to work. All help greatly appreciated!
What happens when you try to import the issues? Do you see any error messages or does nothing happen?
Just to check, is query you added at root level, i.e. Shared\Query? If the query is at Shared\Folder\Query, you won’t get any results.
Hi there Danielle,
I don't get to select the query at all on the config setup! Yes, the query is at Shared\Query.
Were you using an updated personal access token as your password in the configuration pop-up? It's possible that it expired.
Hi Danielle,
I created a new one for this purpose.
Thanks for that info. Would you be able to attach your log files here? They can often reveal some more information behind the issue.
