Customizing the connectors
Need Answer Harshd ● 6 years ago
I want to create a process flow diagram on Justinmind. I am using the Screens window and the diagramming widget kit. I have created 10 activities and want to showcase a connection between Activity 1 and Activity 10, with a description written on the arrow itself.
The connectors only connect 2 activities horizontally but I am not able to customize them as the flow is quite complex.
Is there a way I can do it?
You will need to select the elements in the group and rotate them manually. That will be easier in the next version (version 9).
