Cannot upload/share the prototype to the server "Unknown Error"
In Progress FX Yunianto W 4 years ago
When I am trying to share the prototype (teamwork/ share) it provides me an "unknown error" after a while during the uploading process:
Please try again, there was an issue with the servers this morning.
I have succeeded in uploading the prototype, but when I click "public prototype" it always loads more than 1 hour and ends "failed"
We plan to launch some improvements this weekend. This issue should be fixed by Monday.
Please let us know if there are any other issues you are running into.
the repairs should be done immediately, because I need this prototype for my work report.
another obstacle I encountered was when I wanted to "EXPORT DOCUMENTS"
If it's not too much trouble, could you attach your log files and prototype so then we can replicate the issue on our side?
You can find your log file by following this file path:
To attach your prototype you can compress it to a .zip/.rar and attach it here.
attached I send the prototype in rar form
attached I send the prototype most updated in rar form
hey chloe, Is this problem unsolved?
Thank you for your patience. We are still working on a solution but in the meantime you can use the option File - Export - Customized Document and then select a subset of screens every time.
Please let me know if you have any other questions while we're working on a solution.
Hi Chloe, why can't I export documents until now ?
this is the result of my document export :
/9d1007072a2527f759054e82044c0300
Thank you for your patience, our team is still working on a solution. I will update you once we have fixed this issue.
Please let me know if you have any other questions.
We have identified a memory leak and our team should have it fixed by next week.
