App Interface Not Working Correctly
In Progress Tahademirer 4 years ago
I just downloaded Justinmind Windows version and installed it. But it looks like not working correctly. I can't see some of buttons. Attached a screenshot.
Could you try uninstalling it following these steps and seeing if it helps?
- Uninstall version 9
- Go to your user's folder, open the Justinmind folder there and delete any folder that has 9.0 or any version starting with 9
- Download the installer from here https://www.justinmind.com/download
- Install and launch again
Please let me know if this is the process you followed and if it still didn't work.
Hi Chloe,
I followed the steps you wrote and still having the same problem.
That is odd. Could you attach your log files so we can take a look at what the problem might be?
Hi, this is the file you asked for.
Files: logs.log
Thank you for attaching your log files. We are taking a look to see what the possible problem could be and will let you know when there is a solution.
Thank you for your patience,
Could you try updating to Justinmind version 9.1.5 that was released on October 21st?
