Simulate prototype stopped working
Known Thomas Krause 4 years ago
After updating to JIM 9 a couple of weeks back everything seemed to work fine.
Now unexpectedly (in a customer session) Simulate prototype stopped working. It shows the page in a fragmented raw HTML way, not usable.
I've attached a screenshot and the JS console log.
Could you send us your log files so then we can take a look and find a solution?
Here's the log.
Files: logs.log
Could you try following this process to uninstall Justinmind and then reinstall it?
Here is how:
- Uninstall version 9
- Go to your user's folder, open the Justinmind folder there and delete any folder that has 9.0 or any version starting with 9
- Download the installer from here https://www.justinmind.com/download
- Install and launch again
Please let me know if this works.
Same issue. Here's the log file entry:
[2876856548222340219] [2020-11-23 09:53:03] INFO com.justinmind.generator - simulation: [installPath=/C:/Program Files/Justinmind/Justinmind 9.1.10/app/configuration/org.eclipse.osgi/10/0/.cp/, outputPath=C:/Users/Thomy/Justinmind/9.1.10/work/-2133172550342298117/, optimize=true]
[2876856548222340219] [2020-11-23 09:53:03] ERROR com.justinmind.generator - generation failed
[ACCESS_DENIED, PATH_ERROR] com.justinmind.generator.engine.GeneratorException: java.io.IOException: The filename, directory name, or volume label syntax is incorrect
at com.justinmind.generator.engine.output.pM.a(pM.java:25)
at com.justinmind.generator.context.htmlwidget.HtmlWidgetController.generate(HtmlWidgetController.java:55)
at com.justinmind.generator.engine.pB$uY.run(pB$uY.java:158)
Caused by: java.io.IOException: The filename, directory name, or volume label syntax is incorrect
at java.base/java.io.WinNTFileSystem.createFileExclusively(Native Method)
at java.base/java.io.File.createNewFile(File.java:1024)
at com.justinmind.util.file.FileUtils.deepCreateFile(FileUtils.java:124)
at com.justinmind.generator.engine.output.pO.a(pO.java:45)
at com.justinmind.generator.engine.output.pO.a(pO.java:32)
at com.justinmind.generator.engine.output.pM.a(pM.java:17)
... 2 more
Just an idea: ACCESS_DENIED on an installation directory is understandable, shouldn't a process write into the user directory instead?
OK, ignore this comment. C:/Users/Thomy/Justinmind/9.1.10/work should be writable.
Thank you for trying that approach. Does this problem only happen with a specific prototype?
Indeed. It doesn't happen for my older prototypes. I can send you the problematic one if you want to drill into the issue. What's a good channel to send it to you?
You can compress the .vp file into a .zip/.rar and attach it here. Once it has been downloaded, we will delete it from the comment so then no one else can look at it.
