How to show data from the datalist?
Need Answer Magdalena Koenig96 4 years ago
I tried to make a Data grid and edit the informations with a click on a button. My problem is that I can't make the data from the datalist visiable on my new screen. I already did everything according to the tutorial but it still doesn't work (https://www.justinmind.com/support/prototyping-forms-data-lists-and-data-grids/) - did I miss something? I linked the variable (SelectedRow) with the current grid, set the event actions and linked the forms with the SelectedRow-variable and the data master field (via the SELECTION-field).
Thank you in advance for your help.
That is odd. Could you attach your prototype so then I may take a look at it? You can compress your .vp file to a .zip/.rar and attach it here.
