Picker component
Known Lcsqlpete 4 years ago
Is there a pre-built component for what I believe is called a picker in the Apple iOS user interface guidelines? It's basically a modal screen overlay lists options available for the user to select.
To achieve this you will need to create a IOS Prototype/Screen, then use this component (which is accessed through the toolbar, inside the 'plus' icon and inside 'Input Fields':
unknown
Then simulate. That component, in the simulator, will work as the picker you want.
Please let me know if you have any questions.
I do not see the component you mentioned. I see a Select List component in the Forms and Controls section which does act like a picker when simulated but the component's appearance looks similar to an html select menu before it is clicked (image attached). Is there a way to change its appearance? I need to picker to appear when the user taps a normal button.
Maybe the problem is that I don't have the Dropdown/Select list component you mentioned, not sure why that would be.
Thanks,
Pete
