Remove licence from
Known Diogo Malheiro 4 years ago
Hello
How can i remove clients where i had activated?
Im trying to login and since it is saying that the license is activated in other computers, i cannot login. I could not find anywhere so i could remove it from the admin portal...
I have removed the activations that were on your account so now you can use Justinmind on two computers.
Let me know if this works.
Hello Chloe,
I'm trying to login now and i'm having the same problem. Probably it had not work when you removed the activations.
Can you do it again?!
Regards,
DM
I just reset your activations. You can now use Justinmind on 0/2 computers. Let me know if this works.
