Can't pin groups
Under Consideration Carlos 4 years ago
I can't pin groups of elements, which is a big nuisance since for instance I can't do things like pin a menu bar to the top. It forces me to pin individual elements (our menu bar consists of 200 elements, which is a pin to go one by one) and we want to avoid grouping it as a dynamic panel since then it will mess up hotspots, etc. since these will be under, etc.
Unfortunately you cannot pin groups. The only workaround is to group elements in a dynamic panel and pin the panel instead.
Our apologies for the inconvenience,
I can't use a dynamic panel in this case, since dynamic panel would occupy a very large area and since it has certain elements that must be in front (it is a menu bar common to many pages), it would cover all the elements of each page.
It would be very practical and productive to allow groups to be pinpointed. I undestand that groups can't have an event, but it does make sense that groups can be pinpointed to be fixed in the page. Could you suggest it to development?
We apologize for the inconvenience. We will consider your suggestion and add it to our backlog in hopes that it will be added into Justinmind in the future.
