Missing Font Segoe UI
Known Rogersk8099 4 years ago
I am having an issue with "Missing Fonts". I am running Windows 10 Pro Version 20H2 (Build 19042.804). When opening my VP file I receive the error saying some of my fonts are missing. Segoe UI has been pre-bundled into Windows since Windows 8 (Developer Preview since build 8130).
I have checked my folder and I can confirm they are present, this is also a fresh install of Windows 10.
Does anyone know how to resolve this issue?
Thank you for reaching out. Try goin to Edit - Replace Styles and then search for Segoe UI and replace with that. Let me know if it works!
in same error, don´t work for me
Which fonts are missing when you run Justinmind?
Chloe, I came to see if someone could give me a solution here, as I have a ticket open in the support system and they have not given me any answers.
I am attaching a screenshot of the fonts that it tells me are missing, being that I have them in the system, and they are not used in the project, since if I look for them to replace it, the program tells me that they are not found in the project.
Greetings
Thank you for reaching out again. I remember your case and am looping in second-support to make a solution for your issue. I will let you know when they get back to me.
Thank you for your patience,
