Using check box to update Boolean values in Data List
Known Sumit Sureka 4 years ago
I am using check box to define the boolean values for data list. So, i have created a method to create a new Row where as user is given the permission to view, delete or modify. The creation of the new row works fine but when i do the same to modify the row, only the values changed for the checkboxes are not getting updated. I am updating the variable to update the row in a similar manner as i did for create i.e. selecting the checkbox and dropping into the modify data master field. All the other input fields are getting reflected but the check box is not (Only for modify)
