Concatenate two texts with an empty space
Known Celina Schulz 3 years ago
Hey there!
I simply want to give a field the value of the first name + empty space + last name. I use the concat function in the expression builder and so far it worked well. The only problem is that if I restart the prototype or publish it, the empty space in the expression builder's text field will vanish. I have to add it every time I restart it.
I also want to share the prototype with users, so even if I add the empty space and publish the prototype, if I simulate it via public prototypes the empty space is gone again. And I cannot find a way to fix that. Can someone help please? Thanks!
Greetings!
Celina
Can you attach a screenshot of what you are seeing? I believe it will give me a better idea of what the problem is and how to help you.
