Input field as Master
Need Answer Simone Wiedemann 4 years ago
I created an input field with a floating label. I would like to use this for the whole prototype and possibly change the behavior later. Therefore I created it as a master not as a widget. However, I cannot adjust the width of the instances of the master or change the label individually. If I create the input field as a widget, the instances on the screens are not updated when I change the widget. How can I solve the problem?
