Using Widget from Library Changes Selection Tool
Under Consideration Will Devi 4 years ago
When I use the widget library it appears that it changes the selection tool setting. This is highly annoying as I have to constantly reset the selection tool.
You can swap quickly between each of those tools with the V key and A key. Let me know if these hotkeys work!
Yeah I know you can do that, but why does it reset my setting from "A" to "V" every time I add a new element. Is really annoying.
That is how the program was designed. I can add this as a suggestion change for a future update if you would like?
Yes please, thanks!
