How do you export an svg? Once again I can't get a straight answer.
Answered Snarffel-1 3 years ago
The answer here is wrong: https://www.justinmind.com/community/topic/what-types-of-files-can-justinmind-export-exactly#
support that answered is confusing export and import - according to Justinmind you can just import svg files into justimnind , but not export
So how exactly is a file exported as an SVG from a Justinmind file?
What are the exact steps to export a file as SVG?
What are the exact steps to export a component within a file as SVG
Thank you for reaching out. At this time you can only export as an SVG file if there is a previously imported SVG file in your prototype. However, in the next update of Justinmind you will be able to export anything to an SVG file. I hope this helps answer your question!
And when will this update happen. I downloaded this program because I need to create an svg file... it feels like false advertising.
hello,
You have two options to export as SVG, right button- Export to image files and And using the 'Slice' tool. - I attach images -
Ria.
for anyone looking for a solution in 2024.
1) group the elements you want to export
f9c989ad8b3bdaad23878b01b7248cca
2) create a slice of the group
63bc30084a3ef3e184856f9db03d4893
3) change the format to svg and export
facb505f9f26db6f81d0b5b842d6f632
NOTE: FONT FAMILY IS NOT APPLIED AND SOME ELEMENTS DISAPPEAR
