Password Interaction not working when click on is selected
Known Brandon Taylor 3 years ago
I am attempting to create a Password Interaction that only navigates or changes style when text input is equal to. The navigation interactions works only if i choose mouse over.
Event Interaction:
When [input.value = 1234]
Do ~ on click navigate to screen in new tab
Else - change style to Red Text
What are you using the Password Authentication on? Is it being used on a Input Text Field or some other Element?
Hello Chloe,
I am using an Input Text Field
If you look at this article: https://www.justinmind.com/support/prototyping-forms-and-inputs/#Validating-required-fields-forms, you can do a "On Click" event using 'Regular Expression'. Let me know if this helps!
