Not able to edit prototype upon reopening
Known Ben 3 years ago
I saved a project and exported it, then close out of the program. When I go to open the program back up, I'm not able to edit the project.
I'm the user on the project. Is there something I'm doing wrong when opening the saved project?
Super appreciate your help!
Thank you for reaching out. Can you attach a video of you trying to move things around in the prototype?
Thank you for attaching that video. Did you create this prototype or did you import some of the elements from another program?
I created this prototype from scratch within Justinmind.
It seems you will need to activate the Templates palette and click on the Template that you want. It appears to be greyed out in the video so that may be the problem.
How do I go about doing this?
Thanks!
If you go to the Templates palette: /9ee43d3d7ecddbcab99c39797fd0e46f
From there you can select the Template that you are working on. If the Template palette is nowhere on your screen try going to Window - Templates and make sure the check mark is there. Let me know if that works!
