Browser view issue
Known Majdah 3 years ago
Each time when I tried to view my work through the browser (even if it's locally), I found different alignment and the items not placed correctly as I designed in workspace.
I'm subscribed member and hope to find solution.
Thank you for reaching out. Could you attach some screenshots of what your prototype looks like when editing and then what it looks like when you simulate?
Here is one example, because I faced this issue many times with different widgets:
I have a table and I add radio buttons in specific locations. At the first time, I adjusted based on workspace view, but in ME browser, it shows in different location, then I changed based on browser view, now the result:
image 1 => in workspace
image 2 => in browser
I need to have one view in both.
Thank you for attaching those screenshots. Can you send me a screenshot of your Layers panel? Particularly of the Elements that are displaying incorrectly when Simulating.
By the way, even if I add fixed pin for each item, I got the same issue.
