Hiding Element on page load
Need Answer Bergeryap87 3 years ago
Attached my question on hiding element when page load.
Select the element, then go to the Properties palette and, in the top of the palette click on the 'eye' icon. If you hover over that icon you'll see a tooltip that says 'Mark this element as hidden'
Noted on your reply and it works, element is hiding on page load.
How can I make that element appear on a tap of some button?
If I use Add Event > On Tap > which function should I use?
