BUG: Cannot edit text for older widgets in version 9
Known Karl 3 years ago
With the item text removed from the property sheet in version 9 it is now impossible to edit the text of several library items created in previous versions of the tool. For example: I added a button from the Bootstrap widget library to a prototype in a previous version of Justinmind. After "upgrading" to version 9, I can no longer edit the text of those buttons because they are group items and not directly selectable in the outline.
You should be able to double-click on the text in the canvas and change it there
